Error seems clear, the page file is too small. Increase the size of Windows' page file.
https://mcci.com/support/guides/how-to-change-the-windows-pagefile-size/
Edit: Btw. you can create screenshots with Windows+Print Key or use the Snipping Tool included in Windows 10. Much easier than using a camera and easier to see, too
nah my friend sent it to me on snapchat ?
