So if your Mac is failing to recover even through, Internet recovery you might need a USB that has macOS on it and try booting off that. Unless there is a problem with the Mac itself then the USB should work. Have you tried accessing the recovery partition?
[DESKTOP] CPU: Intel Core i7 8700k GPU: ASUS ROG 2080TI RAM: 64GB Corsair Fury DDR4 Mobo: Asus z390-A Prime
Storage:1x 1TB Samsung 990 Pro SSD 2x 1TB WD Black SSD, 2x 3Tb Seagate  HDD PSU: Seasonic 950W
Monitors: 2x Asus TUF Gaming 24" 1440p  144hz, 2x LG  75Hz 1080p LED
[SERVER/NAS] CPU: Intel Core i7 7700K GPU: Nvidia 1060 6GB RAM: 32 GB Corsair Vengeance Mobo: Asus z-170P D3
Storage:1x 1TB Western Digital SSD, 4x Ironwolf Pro 12Tb HDD, 2x 2TB WD Blue  PSU: Thermaltake 650W
[LAPTOP (MacBook Pro 16")] CPU: 2.4 GHz 8-Core Intel Core i9, RAM: 32 GB 2667 MHz DDR4, SSD: 2 TB
GPU: AMD Radeon Pro 5500M 8GB Display: 16-inch (3072 x 1920)
https://linustechtips.com/topic/1125707-help/#findComment-13062330
How do I get the usb and I’ve used this tutorial
https://linustechtips.com/topic/1125707-help/#findComment-13062345
What Model is your Mac?
https://linustechtips.com/topic/1125707-help/#findComment-13062351
I mean do you know the Type of Mac you are using like; MacBook, or Mac Pro etc?
https://linustechtips.com/topic/1125707-help/#findComment-13062363
Have you tried booting into the recovery options and reinstalling the OS from the recovery partition?
https://linustechtips.com/topic/1125707-help/#findComment-13062464
Ok, so what you need to do is using another mac or one borrowed from a friend etc, you will need to install macOS to a USB. Then use that USB to boot your current mac and reinstall the OS.
https://linustechtips.com/topic/1125707-help/#findComment-13062810
