I just wanted to see if i should upgrade as i don't want ruin the hear of my build
as originally i built the SFF PC as a way for portable gaming on a
Asus B350m-A Motherboard with aftermarket heatsinks on the mosfets
Ryzen 2400G at 3.9ghz with a Noctua Cooler idk what one but keeps it cool and chill with hardcore gaming
4x4gb ddr4 XMP 2800mhz
with Vega 11 Graphics at 1400mhz core and 1500mhz memory
256mb Sata SSD
new 8tb Hard drive for back up of my main fills
but in general i don't want to take away the purpose of this build, if im gonna upgrade might as well go for a ryzen 2700 and a better graphics card than a 1650 but
if i wanted to keep the SFF case i need a SFF gpu and the 1650 is the newest card but will it be a waste on a 2400g t
this build is one of my favorites kinda a show off on what i can do PC wise, and Intergrated graphics have gone a long way intel kinda sucks on that part
Edited by tjrose91
hit enter to soon and submitted post to soon didn't do Shift+Enter
https://linustechtips.com/topic/1125121-messing-with-my-build/
Just now, Man said:
I'd start by dropping that PC into a mini-tower, if I was you. Not a fan of SFFs. Quite the opposite, in fact.
originally made it so i could transport it between oklahoma and kansas can still play apex at 60fps on low-med settings at 720p
https://linustechtips.com/topic/1125121-messing-with-my-build/#findComment-13057439
Be that as it may, I'm afraid you'll have to put it into a mini-tower to harness its full potential.
Or just drop a low profile mini GTX1650 in there if you aren't into hardcore gaming stuff and want to keep the SFF case, which is understandable in your particular case (No pun intended).
https://linustechtips.com/topic/1125121-messing-with-my-build/#findComment-13057451
could you use a PCIE extension just for the sake of having the option to fold it in?
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1125121-messing-with-my-build/#findComment-13057453
