Hi all!
Not eniterly sure what is happening lately. But i have run into an issue and hope any1 can shed some light on it.
In the recent days while gaming my pc just shuts down, sort off...
What happens is that sometimes my pc will turn off almost completely. It will stop giving signal to my screens, USB ports turn off (no more power as lights on keyboard go off), nolonger responds to any input of any kind. Fans spin as normale, no error codes on the mainboard or anything. Nothing in the Windows logs either.
Thermals have been monitored and are within proper levels (40 to 45c on cpu, package around 36c under load) so it shouldnt be a thermal issue. If any1 has any ideas what it could be. Please post below.
Specs:
MSI carbon x370 (latest bios)
Ryzen 1700 @3600 (fixed)
Corsair vengeance 2*16gb @2900
Evga ftw hybrid 1080
Corsair h110i
G110 keyboard
Ironclaw RGB wireless mouse
Aten 2 port usb3 switch (powered)
Gamesystem: X3700, 32GB memory @3200mhz, GTX1080 Hybrid
Unraid system: Epyc 7352, 24/48, 96GB ECC buffered @2666mhz, 2x GT710, GTX1050Ti
https://linustechtips.com/topic/1124531-issue-with-a-poweroff/
is probably ur reason,  u didnt set timings properly and speeds
wht u have is most likely a black screen of death,  its more critical then a blue screen, usually caused from ram or unstable gpu, broken mem controler and what not
https://linustechtips.com/topic/1124531-issue-with-a-poweroff/#findComment-13052887
Its set to 2933 via the build in profile. I can always go lower and check ofcourse. But its been running fine for 2 years . . .
https://linustechtips.com/topic/1124531-issue-with-a-poweroff/#findComment-13053167
On 11/17/2019 at 2:33 PM, Valkyrie Lenneth said:
Have just checked my bios, appearantly i have a non existing version installed. 7A32v1NT (not listed on msi website anymore. with a release date of september 10th 2019)
Before i do multiple actions at once, i've first downclocked the memory to 2666mhz. See what happens the comming couple of days (its of sporadic nature)
If i still get it, ill update the bios to the newest beta version 7A32v1NU. If the issue then still persists, ill downgrade to 7A32v1L or 7A32v1K or J.
https://linustechtips.com/topic/1124531-issue-with-a-poweroff/#findComment-13056187
dont get beta versions, but get full version instead to ensure stability, beta can be unstable
https://linustechtips.com/topic/1124531-issue-with-a-poweroff/#findComment-13056264
Thanks for the headsup.
reason i have the beta on it, was because of the agesa update at the time.
It's probably been pulled for a reason, but don't want to get ahead of myself while 'troubleshooting' a sporadic issue.
One thing at a time. If it doesn't come back with memory at 2666, i can always up / downgrade the bios to a stable version, test that out and from there crank up the speeds again.
https://linustechtips.com/topic/1124531-issue-with-a-poweroff/#findComment-13057848
