Hey guys I am looking on getting a new PC! I have been looking at parts for a while and these are the (in my opinion) the best that fit into my budget (around 600€) Also I have found windows 10 for a lot cheaper so don't count it!
I would like to know your suggestions on if it's good for the price and if I should change something!
Thanks in advance!
https://linustechtips.com/topic/1124471-first-pc-build/
7 minutes ago, GeorgeT123 said:
Hey guys I am looking on getting a new PC! I have been looking at parts for a while and these are the (in my opinion) the best that fit into my budget (around 600€) https://pcpartpicker.com/list/ (don't look at the price on PCPartPicker here in Greece I get the same PC for around 650€).
Thanks in advance!
Your link doesn't work.
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1124471-first-pc-build/#findComment-13052467
6 minutes ago, GeorgeT123 said:
I should work now!
Solid Build overall.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1124471-first-pc-build/#findComment-13052496
49 minutes ago, GeorgeT123 said:
I should work now!
Hello
I changed the SSD and GPU for better ones for the same price. You can buy a W10 key on ebay for 10$ instead ;)
https://linustechtips.com/topic/1124471-first-pc-build/#findComment-13052540
