Hey guys, so i having problem on my AMD Desktop. well when i turn on my PC, it boot up, then a minute later, the display just went No SIgnal & both of my Mouse & Keyboard ( of course they are RGB ) they went off either, but the CPU still running. i tried to move mouse or press any key on keyboard, still no respond & when i forced to reboot, it won't display.
CPU & GPU: AMD A8-7650k APU ( i used Integrated GPU )
RAM: Unknown 4Gb 1600Mhz
SSD: Samsong EVO 260Gb & Seagate HDD 1Tb
PSU: Power Choice 580W PSU
https://linustechtips.com/topic/1124401-weird-pc-problem/
maybe its overheating? just my initial thought.
Im with the mentaility of "IF IM NOT SURE IF ITS ENOUGH COOLING, GO OVERKILL"
CURRENT PC SPECS
CPU             Ryzen 5 3600 (Formerly Ryzen 3 1200)
GPU             : ASUS RX 580 Dual OC (Formerly ASUS GTX 1060 but it got corroded for some odd reasons)
GPU COOOER      : ID Cooling Frostflow 120 VGA (Stock cooler overheats even when undervolted :()
MOBO            : MSI B350m Bazooka
MEMORY          Team Group Elite TUF DDR4 3600 Mhz CL 16
STORAGE         : Seagate Baracudda 1TB and Kingston SSD
PSU             : Thermaltake Lite power 550W (Gonna change soon as i dont trust this)
CASE            : Rakk Anyag Frost
CPU COOLER      : ID-Cooling SE 207
CASE FANS       : Mix of ID cooling fans, Corsair fans and Rakk Ounos (planned change to ID Cooling)
DISPLAY         : SpectrePro XTNS24 144hz Curved VA panel
MOUSE           : Logitech G603 Lightspeed
KEYBOARD        : Rakk Lam Ang
HEADSET         : Plantronics RIG 500HD
Kingston Hyper X Stinger
and a whole lot of LED everywhere(behind the monitor, behind the desk, behind the shelf of the PC mount and inside the case)
https://linustechtips.com/topic/1124401-weird-pc-problem/#findComment-13051908
cause that symptom ever only happens to me when the graphics driver crashes.
CURRENT PC SPECS
https://linustechtips.com/topic/1124401-weird-pc-problem/#findComment-13051946
