Greetings, LTT Community!
I have a question about a build I'm planning. I'm looking into building a new itx system, and I'm wondering if the cooler will fit. The cooler is the new LTT Noctua NH-D15. I've checked pcpartpicker, and it says it will fit in the case. However, I'm more concerned about the Motherboard. The Motherboard I'm planning to use is the Asus X570-I Gaming ITX Motherboard. The Concern comes with the reasonably large heatsink covering the M.2 Slot. I'm wondering if anyone else has used this Motherboard with the NH-D15. The Case (NZXT H210i) Will fit the cooler perfectly, its just Asus's website doesn't seem to list the correct dimensions for the heatsinks. Thank you for taking the time to read!
https://pcpartpicker.com/user/IncumbentOdin4/saved/#view=CcmwhM
https://www.asus.com/us/Motherboards/ROG-Strix-X570-I-Gaming/
https://linustechtips.com/topic/1124378-will-it-fit/
Board vendors wont make something that tall / Cooler makers wont make heatsinks this low. Cant find examples with this board but one with the X470 board
https://pcpartpicker.com/b/ft29TW
Desktop benching:
https://linustechtips.com/topic/1124378-will-it-fit/#findComment-13051770
Thank you for the help, I appreciate it! :)
https://linustechtips.com/topic/1124378-will-it-fit/#findComment-13051785
  • 1 year later...
  • 2 weeks later...
  • 3 weeks later...
