CPU Cooler Questions
26 minutes ago, J-C said:CPU: Intel Core i7-8700K 3.7 GHz 6-Core Processor
Motherboard: Asus ROG MAXIMUS XI HERO (WI-FI) ATX LGA1151
Memory: G.Skill Trident Z 16 GB (2 x 8 GB) DDR4-3200 Memory
Video Card: Asus GeForce RTX 2070 8 GB STRIX GAMING OC
Case: Corsair Carbide Series 678C ATX Mid Tower Case
Power Supply: Corsair RMx (2018) 850 W Modular ATX.
9700k is the better deal unless the price is significantly higher. It has better cooling without delidding (thx soldering) and without HT, so no hit from HT related vulnerability patches
that board is the worst of high end Z390 boards with highest VRM temperature (tho still acceptable) but without major selling points, and in general Asus' Z390 boards arent good deals at all due to their high price. Gigabyte and MSI (you'd be getting the Aorus Master or Ace of this budget) is much better.
3600MHz CL16 memory is preferred
2070 Strix probably cost more than a decent 2070 Super from other brands, while being slower.
678C's front panel is mostly sealed, it wont do well in terms of silent due to the fan speeds needed to make airflow sufficient
PSU's overkill (750w is more than enough for 9900k + 2080ti), but this is the least of the problems of this list
33 minutes ago, J-C said:If you didint notice i dont have any CPU coolers.So this is why i need to ask you.
Witch one is gonna fit in the case and with the LGA1151 socket (CPU gonna be overclocked),and performs best,and features of them.So let me put the list that i was thinking of.
X62 is the best performing, DRP4 has the least chance of a fail (no pump involved) and least serious consequence (very unlikely for the heatpipes to leak their content, and even if they do there's very little in there that would drip since there's little to begin with and evapourate quickly)
