I'm looking to change or upgrade my cpu cooler.
acording to msi afterburner my cpu and gpu can get tempatures to 70 tot 80 degrees under load from new games,
also it happens a few times that my ssd gets overheated from the heat and makes my pc go bluescreen and on restart saying that i have no boot drive.
my pc boot normally agein after taking of the side panels let it cool off. This alredy happend a few times and im getting tired of it so i was hoping to change it to a AIO liquid cooler.
these are my parts that i'm currently using:
-------------PC SPEC----------------
CPU: Intel i7-6700k
GPU: aorus rx 580 8gb
RAM: Kingston 16GB 1600MHz DDR3
CPU cooler: be quiet! shadow rock 2
Motherboard: MSI z170A pc MATE ATX LGA1151
Storage: Samsung SSD 750 EVO 250 GB
WD Blue 1 TB 7200 RPM
PSU: Cooler Master G550M 80+ bronze
case: NZXT Phantom 410
(im looking towards a 120 rad to 240 rad (that fits in my case) AIO liquid cooler and my budget is 80 - 100 euro (RGB is not really needed) )
edit: if you are saing that its a airflow isue i know my cpu cooler takes most of my space in my case so this is why i whant to upgrade to a AIO cooler but dont know wich one to get with my mobo and cpu
edit 2: also around christmas or early 2020 i'm looking to upgrade my cpu, modo and ram so if i get better cooler in advence i dont have to worry in the future to get that upgradet.
https://linustechtips.com/topic/1123359-change-my-cpu-cooler-to-liquid-cooling/
that sounds much more like a case airflow problem
Desktop benching:
the thing is the cpu cooler i now have is so big that it takes most of the space in my case thats why i whant to change to a AIO liquid cooler to have more space and better airflow
then how could so many people get away with the same sized if not even larger coolers? Adding case fans is way cheaper than adding liquid coolers, especially after filering out bad AIO coolers like the Cooler Master ML240L
Desktop benching:
