[Need Help] Updating bios
Solved by paddy-stone,
Just now, Amenadiel said:What i meant is, if i only wanted to update it to F25 and im currently on F3,or do i have to update each version one by one like F5, F6, F7 til i get to F25 or i could just go ahead and update to F25 directly?
If it's under 31, then you can just update to it directly. BUT, why do that? if you're gonna update BIOS anyway, update it to the latest unless it removes support for the CPU you're using of course.
