Need help deciding between displays
So... I need a new monitor but I can't decide between to variants and also need some recommendations.
My budget is around 500€ so around 550$
I would want 100+Hz, IPS and 1440p.
Now the options:
1st: 34" Curved Ultrawide
2nd: 27" non curved
Any suggestions?
And what option would you go for?
https://linustechtips.com/topic/1123050-need-help-deciding-between-displays/
What models?
I use an UW and havent been happier, but it really depends what you use it for.
