Hello.
I have a problem with NIC on my laptop. About a month ago I noticed that laptop disconnected from WiFi, attempted to reconnect and suddenly whole list of all available networks disappeared, after restarting laptop all of them reappear and I connect to my WiFi normally. This problem happens to be random, I can't really see any pattern, can happen ten times a day or everything works for a week. I tried Driver Easy software to update network driver but without any results. Is it my NIC faulty or some kind of driver incompatibility?
https://linustechtips.com/topic/1123002-nic-problem/
https://www.howtogeek.com/198758/never-download-a-driver-updating-utility-theyre-worse-than-useless/
have you tried the windows netowrk reset thing? (windows 10)
https://linustechtips.com/topic/1123002-nic-problem/#findComment-13040999
What laptop are you using? Does it come with a proprietary wireless manager, for example some older Dells ship with a wireless nic utility?
If you are not using the default network utility try uninstalling the proprietary one (not the device drivers) to see if that helps.
https://linustechtips.com/topic/1123002-nic-problem/#findComment-13046543
