Question: Is there a way to prevent drifting onto other screens in a multi-display setup?
Well I've certainly never heard of someone being distracted by the cursor.. It's usually the issue of not being able to find it for me
You could use arrow keys or page up/down
Spacebar and shift-spacebar will also do it.
That was more so one example of where I have issues with multi-monitor configs. I mean, really, I usually turn off all my other monitors and disconnect them in Windows unless I feel I will actually use them. Otherwise, I don't. Because of this very reason. Not strictly because of when I browse websites, but, in general, me managing something and the cursor going to another monitor which interrupts my workflow.
Like, it's a minimal distraction, but if I could mitigate it, that'd be great. Read below for more insight into why that won't work for me.
Neither of my other monitors are suitable for it.
I have multiple monitors. But I don't have them setup how you might imagine it. One monitor is almost completely out of sight for me. It's where my Virtual machine is running so that other people can use my computer when I'm on it. It's not the issue though.
My other monitor is to my left (the virtual machine monitor is left of that monitor), but it's for monitoring things. SGMiner, downloads, etc etc. Things I rarely interact with but want to see to make sure it's running. It's the issue.
So moving this webpage to another monitor isn't a good solution.
Reading this I wonder if going into settings and telling the OS that the monitors are above or below your primary might be a reasonable compromise. That way you don't accidentally go to the side because the computer won't have a monitor there.
