Gunna need to go Ryzen, 3600 or something, can go down to. Wait till black friday/cyber monday and snatch the best deal you can find and build off that, no fewer than 4 cores look for 6 or 8, and a radeon 5700XT or a 1080TI, I doubt you will get decent gaming abilities at 4k for under $900 USD unless you already have some parts.
https://linustechtips.com/topic/1122101-help-plz/#findComment-13033617
Here's some pricing from PCpartpicker with your build in mind. Getting on 4k is gonna be difficult unless you wanna spend more. This build will let you play at 1440p at least.
You also might want to wait for Black Friday. These prices will definitely get lower.
The deep blue sky is infinitely high and crystal clear.
私はオタクではありません。
https://linustechtips.com/topic/1122101-help-plz/#findComment-13033660
