Hi i just installed a corsair h150i pro on my motherboard. My motherboard is the asus crosshair viii hero wifi.
Now the issue is when i boot it sais i have a cpu fan error. but my fans are connected to the cpu waterblock and not the cpu fan header.
The things i have connected are 3 fans to the waterblock, 1 sata power line to the psu, 1 usb header and 1 cha_fan1 header.
How can i solve this i really need help with this i am clueless thanks in advance.
https://linustechtips.com/topic/1121828-cpu-fan-error/
https://www.manualslib.com/manual/1344538/Corsair-Hydro-H150i-Pro.html?page=5#manual
You need to connect the fan header to the CPU_fan, if not it throws an error... you can work around it on some boards.
Please quote my post, or put @paddy-stone if you want me to respond to you.
  • PCs:-
  • Main PC build  https://uk.pcpartpicker.com/list/2K6Q7X
  • ASUS x53e  - i7 2670QM / Sony BD writer x8 / Win 10, Elemetary OS, Ubuntu/ Samsung 830 SSD
  • Lenovo G50 - 8Gb RAM - Samsung 860 Evo 250GB SSD - DVD writer
  • Displays:-
  • Philips 55 OLED 754 model
  • Panasonic 55" 4k TV
  • LG 29" Ultrawide
  • Philips 24" 1080p monitor as backup
  • Storage/NAS/Servers:-
  • ESXI/test build  https://uk.pcpartpicker.com/list/4wyR9G
  • Main Server https://uk.pcpartpicker.com/list/3Qftyk
  • Backup server - HP Proliant Gen 8 4 bay NAS running FreeNAS ZFS striped 3x3TiB WD reds
  • HP ProLiant G6 Server SE316M1 Twin Hex Core Intel Xeon E5645 2.40GHz 48GB RAM
  • Gaming/Tablets etc:-
  • Xbox One S 500GB + 2TB HDD
  • PS4
  • Nvidia Shield TV
  • Xiaomi/Pocafone F2 pro 8GB/256GB
  • Xiaomi Redmi Note 4
  • Unused Hardware currently :-
  • 4670K MSI mobo 16GB ram
  • i7 6700K  b250 mobo
  • Zotac GTX 1060 6GB Amp! edition
  • Zotac GTX 1050 mini
https://linustechtips.com/topic/1121828-cpu-fan-error/#findComment-13031825
I just did i found something on youtube if i ignore the cpu fan speed it works cpu fan header is 4 pins and i need a 3pin connection
https://linustechtips.com/topic/1121828-cpu-fan-error/#findComment-13031828
Just go to the BIOS and ignore the fan in question in the fan section of BIOS.  I don't know if this is the right advice but give it a shot.  My fan also gives error upon bootup so I disabled it or ignore it should I say.  For some reason your main CPU fan might be low on the boot up sequence.
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
https://linustechtips.com/topic/1121828-cpu-fan-error/#findComment-13031846
3 pins will still work on a 4 pin header just FYI. But as @Turtle Rig said, you can disable the fan warning in the BIOS, which is what I meant by
Quote
To disable the fan warning.
Just out of interest, do you have any other fans in your setup? if so you can just plug it/them into the CPU fan header also to stop the fan error appearing... all that warning does is alert you if your fan is not running, to stop your CPU from overheating. So if you don't need it because you are using a water loop etc, then it's perfectly fine to disable it.
What I do on mine, is have a fan hub plugged into the CPU_fan header, then whatever fans I have plugged into that hub are controlled by that header, so if my CPU is getting hotter, the fans adjust to cool it down. I usually have my intake fans, and exhaust fan hooked up to that hub, so it is drawing fresh air into the case to cool the components, and the exhaust fan is drawing some of that air over the heatsinks and out of the case, to cool the VRMs etc.
  • PCs:-
  • Displays:-
  • LG 29" Ultrawide
  • PS4
  • Nvidia Shield TV
https://linustechtips.com/topic/1121828-cpu-fan-error/#findComment-13033215
Thanks for the info but i already solvved that issue i disabled it in the bios like u said. would you be able to take a look at this?
https://linustechtips.com/topic/1121828-cpu-fan-error/#findComment-13033220
