Hi everyone! Whilst rebuilding my PC, I managed to somehow pull the housing from the USB 3.0 header - I shall also name this connector the Devil now, albeit I never had any issues with it in any of my other builds...
So, my quesiton would be, shall I try to put the housing back in? I haven't noticed any bent pins. Or should I connect the connector without the housing? I don't mind if it is loose and can get out, since I don't move my PC a lot.
The mobo: ASUS B450-I STRIX (m-ITX, so no PCI-e expansions and extra USB2 Headers)
The case: Cooler Master Q300L
Here's a link to another unlucky guy to whom it happened. Please have a look from 0.55 to 1.15
https://youtu.be/Q6SWIXgtg4M?t=54
PC booted, temps are fine, everything works as expected, would just like to be able to use the front panel connectors as well.
Cheers!
https://linustechtips.com/topic/1121548-usb3-header-issue/
