so as the title says thermal radar not starting it is the sabertoth 990fx R2 mobo
i have tried reinstalling it no luck there
changed from windows 7 to windows 8.1 pro no luck
it used to work some people say that it is Norton 360 changing the registry but i disabled it before i installed it
l Intel Core i7 4790K @ 4.5Ghz l Asus VII Ranger ROG l MSI GTX 970 @ 1555MHz l
PC PART PICKER
https://linustechtips.com/topic/112129-thermal-radar-not-starting/
download newest aisuite then install it again can be a corrupt file in the installation. if not chek if norton is blocking it.
EOC folding stats - Folding stats - My web folding page stats
Summer Glau: Quote's The future is worth fighting for. Serenity
My linux setup: CPU: I7 2600K @4.5Ghz, MM: Corsair 16GB vengeance @1600Mhz, GPU: 2 Way Radeon his iceq x2 7970, MB: Asus sabertooth Z77, PSU: Corsair 750 plus Gold modular
My gaming setup: CPU: I7 3770K @4.7Ghz, MM: Corsair 32GB vengeance @1600Mhz, GPU: 2 Way Gigabyte RX580 8GB, MB: Asus sabertooth Z77, PSU: Corsair 860i Platinum modular
chek if norton is block the file.
Hello,
Sorry for the trouble. I am Vineeth and I am from the Norton Support team.
I do not think Norton is blocking this programs. However; to confirm this, go to system tray, right-click the Norton product and then select "disable Auto-Protect" and "disable Smart Firewall." Let me know if the problem persists.
Thanks!
Vineeth
Norton Support
Hello,
Thanks!
Vineeth
Norton Support
thanks for commenting it is not Norton it must be a problem with windows 8.1 and the software
PC PART PICKER
