Hello guys I need you help, will my core i7 2600k @ 4.4ghz bottleneck my 7970's in crossfire?
Specs
Case- Cooler Master Haf X
CPU- i7 2600k @ 4.4
CPU cooler- Nzxt Kraken x40 in push pull with Noctua NF-A14 fans
MB- Asus Sabethooth Z77
Memory- 16gb Corsair Vengance @ 1866mgz
SSD- Vertex 4 256gb
Second Storage- WD Caviar Black 2tb
Power Supply- OCZ ZX 850w
GPU- 2x Sapphire 7970 ghz ed. 6gb ram
Sound Card- Asus Xonar DX
Opc Drive- Pioneer Blu-Ray burner
Windows 8
CPU- i7 2600k @ 4.4
MB- Asus Sabethooth z77
SSD- Vertex 4 256gb
GPU- Asus Strix Geforce 980
Opt. Drive- Pioneer Blu-Ray Burner
Monitor- Asus ROG Swift
Windows 7
https://linustechtips.com/topic/11211-bottleneck-help/
Ok thanks, my PCI slots are running at 2.0 because of the CPU, do you thinks is worth to upgrade my CPU?
CPU- i7 2600k @ 4.4
SSD- Vertex 4 256gb
Windows 7
https://linustechtips.com/topic/11211-bottleneck-help/#findComment-119592
This build is relatively good. Bottlenecks should not be such a problem at all.
Andres "Bluejay" Alejandro Montefusco - The Forums Favorite Bird!!!
Top Clock: 7.889 Ghz Cooled by: Liquid Helium
#ChocolateRAM #OatmealFans #ScratchItHarder #WorstcardBestoverclocker #CrazySexStories #SchnitzelQuest TS3 SERVER
https://linustechtips.com/topic/11211-bottleneck-help/#findComment-119606
Thanks guys for the feedback
CPU- i7 2600k @ 4.4
SSD- Vertex 4 256gb
Windows 7
https://linustechtips.com/topic/11211-bottleneck-help/#findComment-119608
No even at stock settings it would be way more then enough CPU power in that system for crossfire. Unless your PCI-E is not running at 8x 8x.
https://linustechtips.com/topic/11211-bottleneck-help/#findComment-119632
Yup. You'll be okay. Way okay. Nice build by the way.
https://linustechtips.com/topic/11211-bottleneck-help/#findComment-119651
Thank you all for answering my question, and yes it is running al 8x 8x.  Thanks guys.
CPU- i7 2600k @ 4.4
SSD- Vertex 4 256gb
Windows 7
https://linustechtips.com/topic/11211-bottleneck-help/#findComment-119807
