It connects to an internal USB for power control
Folding Stats
SYSTEM SPEC
AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb
PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro
Sound Logitech Z560 THX | Operating System Windows 10 Pro
https://linustechtips.com/topic/1120996-need-help/#findComment-13025276
Here's the deal: the connector that goes from the node to the motherboard actually connects to a bog standard USB Micro-B port on the node. You can plug it into any usb port with a standard usb micro-b to usb-type A cable, like you would use on a cell phone.
The only other issue is the fact that it draws power through a SATA connector. You'll need to supply it with enough juice to keep it from blowing out, which will depend on how many strips you use. For a small number of strips, you will be able to get by with a high quality SATA power adapter like they use for external hard drive docks, but I would use a multimeter to make sure it's supplying enough amperage to satisfy the draw.
What I did is just mount a power supply directly to my desk with an on/off switch, so I can turn that on to power the two lightning node pros powering the lights around my setup. I'm currently running 22 strips along my desk, on the back of my monitors, on my monitor/speaker stands, and on the outside of my case
Post image
https://linustechtips.com/topic/1120996-need-help/#findComment-13025843
