Hi, im planning on building my first pc. I chose some parts but i would like to know some opinions if this is going to work, if there are better choices or anything else. I dont have a stated budget (less than $2000 dollars), and i really like this build.
The parts are:
- INTEL I7 9700k 3.6 Ghz
-  MSI GEFORCE RTX 2060 Gaming z
-  ASUS PRIME Z-390 A
-  CORSAIR VENGEANCE RGB PRO 16gb (2 of 8gb) 3200 megahertz
- SEAGATE BARRACUDA 1tb
- EVGA - 850W ATX12V / EPS12V 80 Plus Gold Modular Power Supply
- (maybe) COOLER MASTER C700P Case
- (maybe) NZXT KRAKEN x72 liquid cooling
About peripherals (not really important)
- razer huntsman elite
- mouse pad REDRAGON ORION P001
- msi optix 24" MAG24C 144Hz Curved.
Please let me know. Thanks
https://linustechtips.com/topic/1120844-pc-build-help/
expensive board for what little it offers
Overkill, 2060 + 9700k wont need more than 500W PSUs.
Huge for what it holds
money better spent elsewhere rather than a premium cooler
No SSD? That will suck
Desktop benching:
https://linustechtips.com/topic/1120844-pc-build-help/#findComment-13023832
Have you taken AMD in consideration? 3800X + a X570 board easily fits your budget l.
definitely grab a SSD like @TheGlenlivet mentioned
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1120844-pc-build-help/#findComment-13023834
The parts are:
Here you go. 8c/16t will be plenty for the coming years. 5700XT is a good 1440P card;
not sure if that $2k included peripherals mentioned or not, so left them out (you have $600 left anyways)
https://linustechtips.com/topic/1120844-pc-build-help/#findComment-13024571
38 minutes ago, Plouffe said:
Nice, we don't see a lot of build with 3800x, they should have named it 3700x instead and the 3700x  should have been the 3700.
Who is we? I mean in OP’s budget you could even get away with a 3900x I think.
https://linustechtips.com/topic/1120844-pc-build-help/#findComment-13024650
3 minutes ago, Stormseeker9 said:
Who is we?
We the LTT people (unless I have a multiple personallity disorder I'm not aware of :D)
Yeah but for that price the 3700x/3800x is more reasonable even a 3600 is nice :)
https://linustechtips.com/topic/1120844-pc-build-help/#findComment-13024665
11 hours ago, Plouffe said:
Thank you. This is a really nice build, especially if an expert says it, so i might be going with this one. Maybe just change RAM.
https://linustechtips.com/topic/1120844-pc-build-help/#findComment-13024858
14 hours ago, Plouffe said:
For this build do i have to buy a cooler? I live in Argentina so the only thing that i need to buy is a argentinian cable for the power supply?
https://linustechtips.com/topic/1120844-pc-build-help/#findComment-13025151
If you don't overclock, the included CPU cooler is more than enough otherwise get a Dark Rock 4.
No idea, I know my psu was sent with the standard european cable I suppose they should deliver the correct cable for your area too ? If no, you will need to buy one indeed.
https://linustechtips.com/topic/1120844-pc-build-help/#findComment-13025159
7 hours ago, Pala said:
If i changed the graphics card for a rtx 2060 gaming z 6gb (i cant buy the 2080 because it is sold out near my location), it would still be ok? Could i buy something else with the extra money?
Either get a 5700XT or 2070S because there is a huge gap between the 2060S and 2080S. You can still use the money to get an air cooler like the Dark Rock 4 or NH U14S.
@Stormseeker9 and I made solid build and the 2060S would be a real downgrade.
https://linustechtips.com/topic/1120844-pc-build-help/#findComment-13030305
