Hi,
I need help with the hardware for my homeserver project. I have 200/200 Mbps connection at home and I wan't do something cool with it.
Software for my server: Unraid
Active users ~10.
Services to run via docker:
- Nextcloud with photos, calendar, mail, collabora, on some other 'plugins'
- Airsonic for streaming music, I don't like spotify
- WireGuard for 10 device: Remote tunneled access (routing all traffic through the VPN and out Unraid's Internet connection)
- Minecraft Server for 10 players
- Pi-hole for blocking all ads from the internet
Ryzen 5 1600 with 32gb memory?
https://linustechtips.com/topic/1120843-hardware-for-homeserver/
22 minutes ago, jafi said:
Hi,
Active users ~10.
R5 1600 should be enough for that, but I personally would recommend hardware that is built for 24/7 use. Old xeon powered workstations can usually be picked up for $400 or less and are built with always on operation in mind, with good to great expandability.
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
  • 2 weeks later...
Thank you for the info. Little update. I also would like to run 1-2 VM, OSX and Windows (for AutoCAD). But is 6 cores enough? Ryzen 5 3600 is my current selection, but with those two VM's is it enough? With two GPU. Used xeon are quite expensive here (Europe).
VM's does not need to run 24h. Only when I need them.
