Are you getting any beep codes? Is this a new build? What are your specs? We need info man. Can't just go off some vague video.
PS. If you setup your water loop without testing to make sure the system boots you're in for some shit.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
I'm not getting any beep codes, This pc was only upgraded on Watercooling,
Here's my Specs
CPU:Intel i9-7940x
GPU:GTX1080TI
Motherboard:Aorus X299 Ultra Gaming Pro
RAM:G.SKILL TridentZ RGB Series 32GB (4 x 8GB) DDR4 3600Mhz
Also My Setup was actually booting fine, but after some 3-5boots that happened
Here's my Specs
CPU:Intel i9-7940x
GPU:GTX1080TI
Do a BIOS reset, verify that something is plugged into the CPU Fan header, and boot with a single stick of ram.
PC #1
PC #2
Corsair H80iGT AIO
Laptop
7 hours ago, Fabechk said:
Ok?
PC #1
PC #2
Corsair H80iGT AIO
Laptop
