hey guys, so my pc isas follows
  • CPU
    Intel i7 -5930k
  • Motherboard
    Gigabyte GA-X99-Gaming G1 WIFI
  • RAM
    32GB G.skill (used to be dominators)
  • GPU
    Nvidia GTX Titan Black
  • Case
    Corsair Graphite Series 780T
  • Storage
    Samsung SSD850pro 512GB / 4TB Sagate HDD / 2TB WD HDD
  • PSU
    Corsair AX1600i
  • Cooling
    Corsair H110i 280mm
  • Operating System
    Windows 7 Ultimate
and i know while its ok but titan black is getting VERY old now and cant keep up, so any suggestions regarding the gpu or anything else if not everything that i should change? i've been thinking maybe RTX2070 OC and for the case maybe change it to CoolerMaster's C700M? thanks
https://linustechtips.com/topic/1120201-upgrade-required/
What do you want this computer to do? If it's for games what resolution and refresh rate are you playing at? I would recommend upgrading to Windows 10, Windows 7 is getting pretty old and it's ending its support from Microsoft. The case makes almost no difference to performance, mostly for ascetics.
https://linustechtips.com/topic/1120201-upgrade-required/#findComment-13018345
5700XT does the 2070's job at a lower price, unless you want to record videos or do streaming which you should buy the 2060S (tiny bit slower than 2070, noticeably cheaper) or 2070S (a tier faster, tho does cost more)
Desktop benching:
https://linustechtips.com/topic/1120201-upgrade-required/#findComment-13018370
@Darpyface noted Windows 10, well for the case that's true, guess i'll just replace the fans since they're acting up.
as for res i need something beefy to tame my big 65" 4k TV XD refresh rate isn't that big of an issue since i'm mainly an RPG guy and Call of Duty is a side thing
@Jurrunio i gotta say i have never Ever tried an AMD GPU before but cheap for the same performance sounds like a good trade. and no i only use it for gaming / browsing but sadly no ray tracing on AMD as of yet which is a bummer. guess i'll weigh in how much i want that tech and do the final purchase then
thanks everyone :3
https://linustechtips.com/topic/1120201-upgrade-required/#findComment-13020060
2 hours ago, Coragane said:
no ray tracing
it's not like the current Nvidia cards are good at that either with the massive frame rate dip when you enable RTX effects, tho bad support is better than pretty much none.
Desktop benching:
https://linustechtips.com/topic/1120201-upgrade-required/#findComment-13020442
