My mic is fine. Try Razer Comms :D
My PC CPU: 2600K@4.5GHz 1.3v Cooler: Noctua NH-U12P SE2 MB: ASUS Maximus IV RAM: Kingston 1600MHz 8GB & Corsair 1600MHz 16GB GPU: 780Ti Storage: Samsung 850 Evo 500GB SSD, Samsung 830 256GB SSD, Kingston 128GB SSD, WD Black 1TB,WD Green 1TB. PSU: Corsair AX850 Case: CM HAF X. Optical drive: LG Bluray burner  MacBook Pro, Hackintosh
https://linustechtips.com/topic/112013-razer-karken-pro-help/#findComment-1497589
Make sure you have the right drivers installed? To be honest, most headsets have poor quality mic's. You just may have to live with the quality of the mic. I guess you could go to your microphone settings and play around with them. Try another calling service like Skype and see it sounds any better. It could just be a software issue. Other than that, I really don't know what to tell you.
https://linustechtips.com/topic/112013-razer-karken-pro-help/#findComment-1497596
The microphone on this headset is garbage.
Better than my 7H
https://linustechtips.com/topic/112013-razer-karken-pro-help/#findComment-1497884
