So much info out there...but no real answer for me as to what I need.
What would you guys recommend for a build that can handle the following applications (comfortably)..
Light Gaming: CSGO, Left for Dead, GTA, FIFA
Moderate to Heavy Music Creation: Presonus,  Cubase - Using an External USB Audio Interface - Multi-Tracking Live (8ch to 32ch of instruments & singers)
Moderate to Heavy Graphic Design: Adobe Suite
Moderate to Heavy 3D Logo Animation: Blender
Moderate to Heavy Video Editing: Davinci Resolve (max 4k resolution - 10min final video length max)
Would appreciate your budget, medium and high end recommendations.
Thanks in advance!
https://linustechtips.com/topic/1120128-what-do-i-need-help/
What kind of budget are you thinking of? Easier for us to advise
MSI B450 Pro Gaming Pro Carbon AC | AMD Ryzen 2700x  | NZXT  Kraken X52  MSI GeForce RTX2070 Armour | Corsair Vengeance LPX 32GB (4*8) 3200MhZ | Samsung 970 evo M.2nvme 500GB Boot  / Samsung 860 evo 500GB SSD | Corsair RM550X (2018) | Fractal Design Meshify C white | Logitech G pro WirelessGigabyte Aurus AD27QD
https://linustechtips.com/topic/1120128-what-do-i-need-help/#findComment-13017708
Here's something cheap that will work just fine for your needs :
and here's something more in the middle of your budget - it's missing only a third party cooler (there's stock cooler in the package, but if you want more silent or water cooled pc go for 50-85 uk pounds cooler)
https://linustechtips.com/topic/1120128-what-do-i-need-help/#findComment-13017850
