Hey guys just need help to see if the parts i am going with for my upcoming build is good and if there are any bottlenecks. Your help is appreciated.
  • Ryzen 2700x ($159) - Microcenter
  • Gigabyte B450 Aorus elite ($59.99)- Micorcenter
  • Team T-FORCE VULCAN Z 16GB (2 x 8GB) DDR4 3000 ($59.99)- Newegg
  • GIGABYTE Radeon RX 5700 GAMING OC 8G ($359)- Newegg
  • Phanteks Eclipse P300 tempered glass(white) ($52.99)- Newegg
  • EVGA BQ 600w semi-modular powersupply ($64.99)- Amazon
Total of $755.96
https://linustechtips.com/topic/1119577-build-planning-need-feedback/
he power color or sapphire pulse cards are better if they're the same price
Should get a case with a mesh front so you have proper cooling
The P400 vs the P400a with mesh for example is 15-20C hotter because it's closed off.
and get a nicer power supply at the same price as well.
PCPartPicker Part List: https://pcpartpicker.com/list/6hvJ8M
Case: Fractal Design Focus G ATX Mid Tower Case  ($54.97 @ Amazon)
Power Supply: be quiet! Pure Power 11 500 W 80+ Gold Certified ATX Power Supply  ($69.90 @ B&H)
Total: $124.87
Total: $124.87
What is your budget/country for your new PC? My budget is $800 and im in the U.S
what monitor resolution/refresh rate? i have a hp27er at 60hz right now but i will upgrade 120 or 144 hz in january
What games or other software do you need to run?  i will be doing some software programming using visual studio code/ community and eclipse for some java and other languages. I Will also be doing some video edting at 4k and graphic design. I will be running battlefiled 5, anno 1800, assasins creed, fornite, warframe, and more esport titles.
i also like the case recommendation. hope they discount it on black friday. And as for the power supply  i will keep the current one because i will be adding other components later. I will upgrade within a year of the warranty expiring.
You're better off with an average quality gold unit vs an average quality bronze unit in general, the output is likely a bit cleaner and more stable.
your system isn't likely to pass 300W on average in any event.
PCPartPicker Part List: https://pcpartpicker.com/list/NwKdjc
Power Supply: SeaSonic FOCUS Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply  ($69.90 @ Amazon)
Total: $69.90
Generated by PCPartPicker 2019-11-02 16:28 EDT-0400
