Okay im going to preface this with im both a noob and a dumbass.
Pc specs:
Ryzen 3 1200
Msi b350 pc mate
16gb corsair vengeance
Gigabyte gtx 1060
This morning I decided to overclock my PC in a bit of a dumbass way by starting low with the voltage. I clocked the cpu at 3700mhz which should be fine as ive run it at 3980mhz before however i didn't change the voltage from stock. This time, however, my pc didn't post which is fine but i cleared cmos with both jumper and battery with no avail, it wont pist and my rgb keyboard wont light up when i turn the computer on. It runs just wont post or boot. Any help on any way I can fix it or what the problem is (e.g. Bricked motherboard) thanks ?
https://linustechtips.com/topic/1119477-pc-wont-post-after-overclocking/
Pc specs:
Ryzen 3 1200
Msi b350 pc mate
Gigabyte gtx 1060
Pull power supply cord
Pull power supply cable from mobo
remove cpu
pull cmos battery
let sit overnight (or a few hours anyway)
re-assemble
if it doesn't post, then you fried it
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Pc specs:
Ryzen 3 1200
Msi b350 pc mate
Gigabyte gtx 1060
Looks like your system didn't like the overclock but your sorted that out putting cmos at stock again.  You can't just mess up a computer with a bad OC.  Something fishy is going on.  Listen to Radium_Angel ....
Asus Sabertooth x79 / 4930k @ 4500 @ 1.408v / Gigabyte WF 2080 RTX / Corsair VG 64GB @ 1866 & AX1600i & H115i Pro @ 2x Noctua NF-A14 / Carbide 330r Blackout
Scarlett 2i2 Audio Interface / KRK Rokits 10" / Sennheiser HD 650 / Logitech G Pro Wireless Mouse & G915 Linear & G935 & C920 / SL 88 Grand / Cakewalk / NF-A14 Int P12 Ex
AOC 40" 4k Curved / LG 55" OLED C9 120hz / LaCie Porsche Design 2TB & 500GB / Samsung 950 Pro 500GB / 850 Pro 500GB / Crucial m4 500GB / Asus M.2 Card
remove cpu
pull cmos battery
re-assemble
Thank you so much, I'll give that a try right now
remove cpu
pull cmos battery
re-assemble
Still no post unfortunately, what do I need to replace ? going without pc for a few months then ?
Bummer.
Ok, a few questions to help troubleshoot.
IF your board has a speaker (or a header for one, or you have one plugged in) then you can reconnect just the cpu/cooler fan, and keyboard (no RAM or other things) and power it on.
If it beeps at you, the board is good, as it recognizes RAM is missing, so then a bad CPU.
If it doesn't beep at you, then likely the motherboard is bad (at the very least)
2 hours ago, Radium_Angel said:
Bummer.
Unfortunately I haven't got a speaker plugged into the motherboard. Either way I couldn't afford to replace either of those things
I'm sorry to hear that. Are you in the US?
