Posted November 1, 2019 Good day, I am building my new workstation and cant decide which platform to choose. I am working in Adobe ecosystem (After Effects 40% / Premiere Pro 40% / Lightroom 15% / Photoshop, Illustrator, Audiotion... 5%). AE and PP is main focus for me but I also need versatile machine for exporting lots of RAW images from LR, compressing files etc. Also I am starting working more with 3D (Cinema4D, Houdini). Gaming isnt important for me, I play sometimes but I am sure ever option will be great. I read all recommendation and benchmarks from Pugetsystems, I saw hours of reviews and tests on GamerNexus, Linus media and all over other places and I know how my current machine works and what I need from new one. Unfortunately each application I am using needs different things. AE likes lots of RAM and fast single core performance. PP, 3D apps and LR likes more cores and while I multitasking alot I need lot of RAM. Quick Sync isnt that important for me because I am working with different video footage. So I think I have 3 options: AMD Ryzen 9 3900X + 32GB RAM (I want 64GB but I read Ryzen dont like 4 slots full of RAMs) Intel Core i9-9900KS + 64GB RAM Intel Core i9-9920X + 64GB RAM (maybe later go for 128GB) Price for this setups is simmilar in our contry so key factor will be performance. RAMs are quite expensive here so I will go for 3200CL14 or 3600CL16. Other componets will be same so it doesnt metter (RTX2070 Super, M2 drives + SSDs). Only if I go with X570 I will buy Gen4 M2 SSD but this isnt deal breaker for me. I am sure that 970 EVO Plus will be great option with Gen3 PCIe. Also how strong PSU will be best for selected setup + RTX2070S + 2x M2 + 2x SSD? I am exhausted from all the informations I already absorb and I cant decide what is the best choice. I was already decided to go for 3900X but than I read about not good experience with lots of RAMs. So to be sure I really like to hear some advice from experienced guys in this community. Thank you very much in advance. Link to comment https://linustechtips.com/topic/1119371-cpu-platform-for-workstation/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 1, 2019 I vote for 3900X - for memory don't know if you need more than 32gb of memory - You could start with that and see how it plays out. Gaming PC: CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200 JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 | GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo Linux PC: CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600 JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 | GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax Link to comment https://linustechtips.com/topic/1119371-cpu-platform-for-workstation/#findComment-13012318 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 1, 2019 8 minutes ago, David Svehla said: I am working in Adobe ecosystem (After Effects 40% / Premiere Pro 40% / Lightroom 15% / Photoshop, Illustrator, Audiotion... 5%). AE and PP is main focus for me This makes me positive the best experience would come from the i9 9900K, I would not bother with the KS however as it's really not worth the extra money if you ask me... the 9900KS has a tiny bit lower IPC due to new micro-code for hardware level security fixes so performance wise it almost evens out with a stock 9900K... which can easily be OC'd to 5ghz either ways with proper motherboard and cooling. Adobe is coded in such way it favors Intel's hyper low latency Ring Bus and it has a lot of instances it can use Quicksync to further it's performance, it also is more stable as Intel and Adobe really works hand on hand. You can also get a 3200mhz CL16 kit with the i9 and call it a day. an i9+2070S system would require about 550W, 650W if you want to be on the safe side, you're highly advised to make an individual PSU thread on the proper section. Personal Desktop": CPU: Intel Core i7 10700K @5ghz |~| Cooling: bq! Dark Rock Pro 4 |~| MOBO: Gigabyte Z490UD ATX|~| RAM: 16gb DDR4 3333mhzCL16 G.Skill Trident Z |~| GPU: RX 6900XT Sapphire Nitro+ |~| PSU: Corsair TX650M 80Plus Gold |~| Boot: SSD WD Green M.2 2280 240GB |~| Storage: 1x3TB HDD 7200rpm Seagate Barracuda + SanDisk Ultra 3D 1TB |~| Case: Fractal Design Meshify C Mini |~| Display: Toshiba UL7A 4K/60hz |~| OS: Windows 10 Pro. Luna, the temporary Desktop: CPU: AMD R9 7950XT |~| Cooling: bq! Dark Rock 4 Pro |~| MOBO: Gigabyte Aorus Master |~| RAM: 32G Kingston HyperX |~| GPU: AMD Radeon RX 7900XTX (Reference) |~| PSU: Corsair HX1000 80+ Platinum |~| Windows Boot Drive: 2x 512GB (1TB total) Plextor SATA SSD (RAID0 volume) |~| Linux Boot Drive: 500GB Kingston A2000 |~| Storage: 4TB WD Black HDD |~| Case: Cooler Master Silencio S600 |~| Display 1 (leftmost): Eizo (unknown model) 1920x1080 IPS @ 60Hz|~| Display 2 (center): BenQ ZOWIE XL2540 1920x1080 TN @ 240Hz |~| Display 3 (rightmost): Wacom Cintiq Pro 24 3840x2160 IPS @ 60Hz 10-bit |~| OS: Windows 10 Pro (games / art) + Linux (distro: NixOS; programming and daily driver) Link to comment https://linustechtips.com/topic/1119371-cpu-platform-for-workstation/#findComment-13012324 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 1, 2019 In this case I would also go with a 9900K, no real need to spend extra on a KS. I'm also sure you would be fine with 32GB of RAM, but obviously it won't hurt to have 64 Link to comment https://linustechtips.com/topic/1119371-cpu-platform-for-workstation/#findComment-13012345 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 1, 2019 Author Thank you guys for your comments. I am little bit surprised nobody is talking about 9920X. I read multiple times that if I need lot of RAM and fast response only good way is HEDT and Quad channel DDR. So Intel X series looks very interesting with recent price drop. Link to comment https://linustechtips.com/topic/1119371-cpu-platform-for-workstation/#findComment-13012509 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 1, 2019 Puget Systems has a number of articles with hard data on cpu performance in various programs. The data and analysis are worth looking at as performance of the I9-9900K and 3900X is often close enough that cost may be a deciding factor. If memory serves, the I9-9920X has better performance in Premiere but worse in After Effects. There are z390 and x570 motherboards that support 32GB memory modules allowing for up to 128GB of memory. Corsair and Crucial offer memory kits. 80+ ratings certify electrical efficiency. Not quality. Link to comment https://linustechtips.com/topic/1119371-cpu-platform-for-workstation/#findComment-13013042 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 1, 2019 Author 2 hours ago, brob said: Puget Systems has a number of articles with hard data on cpu performance in various programs. The data and analysis are worth looking at as performance of the I9-9900K and 3900X is often close enough that cost may be a deciding factor. I know I studied them all but it has some misteries for me. Every Premiere Pro render benchmark on Puget is tested with QuickSync On (with 1 pass encode) but I dont use it. I use 2 pass rendering for better quality so the Intel advantage is gone. It is very hard to compare all the benchmarks around internet because I dont know how was set the render. Also QuickSync is supported only with H264 and H265 but I am sometimes working with high bitrate ProRes, CinemaDNG RAWs where you need raw power which Ryzen have more. Overall it seems Ryzen has advantage in every export / render / encode and i9 is better for "work" (playback in PP, ram previews in AE). I only want to know what is the ratio for this diference. If I can gain 25% render / export times and loose 3% work performance I will go for it. But if it will be 25% gain in export and 20% loose in workflow that will be terrible choice. Best "active work performance" is main goal for me. Link to comment https://linustechtips.com/topic/1119371-cpu-platform-for-workstation/#findComment-13013495 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 2, 2019 My perception is that in general the two cpu offer very similar performance. 80+ ratings certify electrical efficiency. Not quality. Link to comment https://linustechtips.com/topic/1119371-cpu-platform-for-workstation/#findComment-13013873 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted November 2, 2019 Dude if you're interested in HEDT then the only way to go is Threadripper 3000. It will bury Intel's Cascade-Lake X in IPC and power consumption. Going Intel HEDT or Intel at all it just a waste of money. Both Ryzen and Ryzen Threadripper have due to the PCIe 4 capabilities tons of more lanes and therefore I/O. It's still your choice but you'd be very happy for going Threadripper. I know that you've watched enough videos, but check out Tom from Moore's Law Is Dead, he makes good videos about Threadripper 3000 vs Intels HEDT lineup. So here's my two cents. Good luck with your decision! CPU: AMD Ryzen 9 3900X | Motherboard: ASUS ROG Crosshair VIII Formula | GPU: AMD Radeon RX 6900XT | RAM: 2*16GB 3200MHz 14-14-14-34 G.Skill Trident Z Royal Silver | SSD: 2TB Gigabyte Aorus Gen 4; 500GB Samsung 860 EVO | CPU Cooler: Corsair H115i RGB Platinum | PSU: Corsair AX850 | Case: Corsair Crystal 680X | Monitor: Eve Spectrum 4K | Keyboard: Logitech G513 Romer-G Tactile | Mouse: Logitech G502 Lightspeed Link to comment https://linustechtips.com/topic/1119371-cpu-platform-for-workstation/#findComment-13014300 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
