Hi there. Im owner of reference 5700xt and this is list of my problems.
1. At 144hz card goes full speed in memory stucks at 1750mhz. At lower hz its normal.
2. Random crashes in games or black screens with no signal. Sometimes it crash by random, but there is some cenarios you crash 100%...
Apex legend: besides random crash or black screen I got crashes doing some action like using ability, using item or opening bin. But 100% I crashing there is end game and anouncer showing "apex legends" here I always crash.crash error famouse hug error + adrenaline sofware not responding after.
For Honor always crash after match when your rewards is showed. Ubi launcher says its drivers and driver software not responding
Paladins random crashes and not loaded models textures... Need some time for textures of heroes to be loaded.
What posible fixes? I used all typical options like DDU, fresh os instal, underclock + fan curve..
One game I have is perfectly fine working is overwatch besides kinda low fps (had almost same performance with gtx 1060.
Also meybe know some games suposibly working good with this 7nm mess...
My setup:
Msi b450 tomahawk
R5 2600 + cooler master ma410m
Patriot viper ddr4 3400mhz
Wd black 500 nvme + wd blue 1tb
Corsair rm 750w gold
Msi reference 5700xt
https://linustechtips.com/topic/1118978-5700xt-problems/
From my 2 months with the 5700 XT, I've learned that it does not play well with overlays, especially its own Wattman overlay. Don't even have Wattman open/minimized, either. Same goes for any performance/monitoring tool (e.g. MSI Afterburner, GPU Tweak, Aorus Engine, etc.), just do not have these running. Went from a hard lock-up / BSOD / CTD every 10-30 minutes with 100% reproduction rate, to not crashing once in over a month and not once ever since.
https://linustechtips.com/topic/1118978-5700xt-problems/#findComment-13009234
