ssd SDD Help!
Solved by mariushm,
You can do it yourself, it's very easy. It's just removing the back panel, unscrewing one screw to insert the new SSD.
There are cheaper options than WD Black SSDs, and for an operating system SSD you won't notice much differences.
Here's some examples:
118$ HP EX920 M.2 1TB PCIe 3.1 X4 Nvme 3D TLC NAND Internal Solid State Drive
See the video below :
