1 minute ago, Pirateparasite said:
So im confused on cpu cooler. Im conflicted on the AIO pinkflow 240 by ID cooling or the Dark Rock Pro 4 by Be Quiet.
Is ID Cooling good? Air cooling or AIO better?
Personally, I would go with the air cooler, because it's cheaper and gets the same job done, but if you don't have headroom in your case for a bigger air cooler, and have the extra money, then get the AIO.
https://linustechtips.com/topic/1117551-choosing-cpu-cooler/#findComment-12998221
I like Air more.
Noctua nh-d15 or Dark Rock Pro 4.
Both almost the same i would say, Noctua  has realy nice Fans tho.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1117551-choosing-cpu-cooler/#findComment-12998224
Is it safe since its not branded like corsair or nzxt?
https://linustechtips.com/topic/1117551-choosing-cpu-cooler/#findComment-12998227
1 minute ago, Praesi said:
I like Air more.
I would go for the darkrock but im trying to go for the pink white aesthetic that the pinkflow has
https://linustechtips.com/topic/1117551-choosing-cpu-cooler/#findComment-12998230
If you have the extra money to spend, and know your AIO is gonna fit in your case, then get it. Just remember if your planning to use this for a long time (5 or more years) then I would just get an air cooler as they tend to last longer.
https://linustechtips.com/topic/1117551-choosing-cpu-cooler/#findComment-12998238
The AIO pinkflow is from a brand called ID cooling but im afraid since people say to get branded stuff like corsair or nzxt
Oh. Make sure to do your research before buying this, so you don't buy something that goes bad in a year. If you're not sure I would get an AIO from Corsair.
https://linustechtips.com/topic/1117551-choosing-cpu-cooler/#findComment-12998260
3 minutes ago, Genwyn said:
i highly recommend the pinkflow, ID cooling is a pretty decent manufacturer of the "chinese aios" all over aliexpress, they made my Aigo aio and thats been doing fine for a long time now
its worth the price tag for the a e s t h e t i c
Speaking from experience?
https://linustechtips.com/topic/1117551-choosing-cpu-cooler/#findComment-12998272
1 hour ago, Genwyn said:
ive built a PC entirely out of aliexpress parts in the past
https://linustechtips.com/main/topic/970597-chinese-only-pc/
ive done a LOT of research into these companies since, to find out which ones are legitimate and which ones are knock offs
and which ones are actually decent knockoffs
ID cooling is a pretty well known brand in the asian market, they make good products, theyre the ones that make the coolers for other brands out there
This was very helpful. I decided what to pick already. Thank you so much. Can i ask you again if i have any other questions about chinese product?
https://linustechtips.com/topic/1117551-choosing-cpu-cooler/#findComment-12998380
Grab DRP4
AIOs smaller than 360mm are a bad choice when u can fit a top end air cooler into a build.
CPU: Intel i7 3930k w/OC & EK Supremacy EVO Block | Motherboard: Asus P9x79 Pro  | RAM: G.Skill 4x4 1866 CL9 | PSU: Seasonic Platinum 1000w Corsair RM 750w Gold (2021)|
VDU: Panasonic 42" Plasma | GPU: Gigabyte 1080ti Gaming OC & Barrow Block (RIP)...GTX 980ti | Sound: Asus Xonar D2X - Z5500 -FiiO X3K DAP/DAC - ATH-M50S | Case: Phantek Enthoo Primo White |
Storage: Samsung 850 Pro 1TB SSD + WD Blue 1TB SSD | Cooling: XSPC D5 Photon 270 Res & Pump | 2x XSPC AX240 White Rads | NexXxos Monsta 80x240 Rad P/P | NF-A12x25 fans |
https://linustechtips.com/topic/1117551-choosing-cpu-cooler/#findComment-12998752
Air coolers and AIO's each have their own strengths. For the two coolers mentioned, the DRP4 is much quieter but performs slightly worse.
What cpu are you cooling and why are you looking at these coolers in particular?
What features are you looking for in a cooler?
If you're mainly concerned with the aesthetic, the Pinkflow cooler can be a decent option as long as it's enough to cool whatever you were planning to use it on.
https://linustechtips.com/topic/1117551-choosing-cpu-cooler/#findComment-13004080
