I have a fairly low spec ATI Radeon 4800 series gpu (it says 4890 the the gpu), and i need help, i play PayDay2, but recently as soon as i launch the game my gpu turns off,resets a couple of times and it turns back on, MSI afterburner shows about 36-39 C on boot, some steady youtube watching it shows 45-47 C, when i originaly started playing with the card i could run PD2 normally on medium-high graphics. But the previously mentioned issue has appeared. I assum the max temp for the gpu is 50C as MSI shows 49-50 before the gpu turns off. I run an older pc Core 2 Duo E8400,4gb of ddr3 ram, and an asrock G41MH/USB3 the psu is 700w. I replaced the cards thermal paste with some Arctic MX-4 2019 edition. These problems werent appearing when i first started gaming.
I also have a 1336 x 768 display (same as before the issues started appearing)
https://linustechtips.com/topic/1117525-gpu-help/
Well, its not the temps they are pretty good. I think you need to upgrade your pc, since its fairly old and your gpu might be broken
I Use my knowledge as business owner and self taught technician aswell as an AI to help people. AI might be controversial but it actually works pretty well 90% of the time.
https://linustechtips.com/topic/1117525-gpu-help/#findComment-12998052
4 minutes ago, begginer_123 said:
The gpu works, is it possible to make the max temp higher
Couldnt find the exact max temp, but 50c is really good temp. I surfed the internet and wound out that its max temps are around 90-105c. And nobody has any heating issues what so ever.
https://linustechtips.com/topic/1117525-gpu-help/#findComment-12998070
  • 3 weeks later...
Ive completley given up on the gpu, ill return to it at some point.
https://linustechtips.com/topic/1117525-gpu-help/#findComment-13050435
It sounds like it's either the PSU not being able to maintain clean power to the GPU, or that one of the GPU's VRMs or other chips that don't have a temp sensor are overheating.
CPURyzen 7 5800X with Arctic Liquid Freezer II 120mm AIO & push-pull Arctic P12 PWM fans RAM: G.Skill Ripjaws V 4x8GB 3600 16-16-16-30
PSU: Be Quiet! Pure Power 12 M 1000W GPUASRock RX 5700 XT Reference with Eiswolf GPX-Pro 240 AIO & 2x Arctic P12 PWM fans Case: Antec P5
MotherboardASRock X570M Pro4 Monitor: ASUS ROG Strix XG32VC Storage: HP EX950 1TB NVMe, Mushkin Pilot-E 1TB NVMe, 2x Constellation ES 2TB in RAID1
https://hwbot.org/submission/4497882_btgbullseye_gpupi_v3.3___32b_radeon_rx_5700_xt_13min_37sec_848ms
https://linustechtips.com/topic/1117525-gpu-help/#findComment-13050473
The gpu is older than me and older than the building im living in, ill probably sell it off to collectors
https://linustechtips.com/topic/1117525-gpu-help/#findComment-13050480
You probably won't even be able to get $10. Not saying you can't try, but it's probably not worth it.
https://linustechtips.com/topic/1117525-gpu-help/#findComment-13050501
