Microphone only works with some programs
Solved by TempestCatto,
A long shot, but right click on the audio icon in the lower right of your taskbar, click recording devices, now right click on your mic and click properties, click the listen tab at the top, make sure the box labeled "listen to this device" is unchecked. Do this for all input devices. See if that changes anything.
Also make sure your mic is set as the default device. There should be two options when right clicking it.
