I'm a first time overclocker and have a few questions.
My specs:
Intel i5 9600k
MSI z390-A pro
MSI core frozor L
16GB 3000Ghz
GTX 1060
Currently I've got 4.6Ghz boost on all cores using an offset of +0.01, and it seems fairly stable at around 60c using up to 1.224v. As I've only got a simple air cooler I don't plan on pushing my CPU too much more, but I'm still not sure how exactly the offset works. When I tested 4.4Ghz it was using 1.16v, but it went to over 1.2v on 4.6Ghz without changing any voltage settings. I want to keep using offset so the voltage drops at idle but should there be that much variance? If I keep upping the frequency will the voltage keep going up? I only plan on doing a mild overclock, hopefully not much over 1.2v.
Any help appreciated, I've only started looking this stuff up in the last few days.
https://linustechtips.com/topic/1117342-cpu-overclocking-questions/
you should use manual mode to find out the best LLC (loadline calibration) setting first, which in manual mode means full load voltage is as close to idle voltage as possible.
Desktop benching:
What do you mean? I though manual means it will run at say 1.2v constantly even at idle.
with lowest LLC level, voltage will plummet under load. This is done to ensure that any behaviour outside factory specs will lead to too little voltage and crash the system instead of burning stuff alive. Raising LLC compensates for this.
Desktop benching:
Still trying to get my head around LLC. I'll see what kind of manual oc I can get in the mean time.
