Using Router as a wifi extender problem.
1 hour ago, MrJunez said:the WebUI is the old webUI of netgear like this one in this image https://www.google.com/url?sa=i&source=images&cd=&ved=2ahUKEwiXpfrW_bPlAhVMU98KHbOUBD4QjRx6BAgBEAQ&url=https%3A%2F%2Fkb.netgear.com%2F120%2FHow-to-configure-a-NETGEAR-DSL-Modem-Router-for-Internet-connection-with-Smart-Wizard&psig=AOvVaw1b_x8zHJ299F6Pv4c4lA-o&ust=1571975084082970
also reason why i wanna run a short ethernet cable is because my router is to far. its in my mothers room and i have several devices to connect to the internet but the signel is poor in my room to be able to connect to that router my main one that is.
If you could run a single wire from the main router to your new one, you could use it as a wireless access-point and a switch... But if that isn't possible, im not sure you can configure the router you have to receive a wifi signal and bridge that to its ethernet ports... You would have to google your specific router and see what the interwebz has to say.
