I just bought & Downloaded 3d mark advanced from steam, benchmarked "3d mark firestrike" and got a score of 8079 with stock clocks, and 8212 with 106% power target.
It appears only 1 card is being used, although SLI is enabled and it's working in other games/benchmarks
Will try restarting comp, bbs.
https://linustechtips.com/topic/111676-low-bench-score/
May be obvious but maybe you haven't installed the latest drivers?
My System Specs: (Short list) i7 4770k, GTX 780, many SSD's, a 2 TB HDD(deceased :( ), Corsair 650D. Full list: http://pcpartpicker.com/user/kchriz6097/saved/8dh7YJ
Upgrade Plan: Acquire some Black Noctuas then add 16 or 32GB of 2133MHz memory
https://linustechtips.com/topic/111676-low-bench-score/#findComment-1492891
They're installed, I'll try a different driver and see what happens.
Using 332.21 atm. Brb, I'll install a different one and test again and post results.
https://linustechtips.com/topic/111676-low-bench-score/#findComment-1492904
Still the same, idk what the issue is ._.
I'll try another driver and see if its the beta one I just downloaded.
Nope, still only using 1 gpu for some reason.  I don't understand >.<.    Everything else works with both gpu's, except this..
https://linustechtips.com/topic/111676-low-bench-score/#findComment-1493002
