Hello guys, Im new to this forum but i have a big problem. I'm playing on wi-fi downstairs where my laptop is, but i want to put a rig upstairs in my room. But i can't bring a cable from downstairs to upstairs (just not possible). I really wanne play with cable in to the internet (direct connection) so i dont need to buy a wi-fi network card... Is there anyway you guys have advice for this? Oh and btw when a tablet connects to my internet my ping goes crazy but when multiple computers connect to it there is no problem like that any tips how i can solve that?
https://linustechtips.com/topic/111587-wi-fi-help/
But i want to have a directly connection with my router? and that powerline is only for a spot that has low wi fi connection?
Buy a cable long enough to reach upstairs.
AMD FX 6300 | ASUS M5A97 R2.0 ATX AM3+ | HITACHI ULTRASTAR 1TB 7200RPM HDD | XFX RADEON HD 7950 3GB | 8GB DDR3-1600 MUSHKIN BLACKLINE | OCZ ZT 550W 80+ BRONZE PSU | ZALMAN Z5 PLUS CASE | LITE-ON iHDS118-04 DVD/CD DRIVE | BENQ GW2255 21.5" MONITOR
https://linustechtips.com/topic/111587-wi-fi-help/#findComment-1491897
That is the problem that can't happen....
You've just gotta deal with it. I had the same problem as you but in the end I just moved it to the living room. By a good wifi adapter or move. Its the only two options.
Sorry.
https://linustechtips.com/topic/111587-wi-fi-help/#findComment-1491915
Sorry.
I can't have a rig downstairs :/ i'll just have to buy a wi-fi network card i guess cuz the connection is no problem i just wanted a stable one.... But do you have any tips on that TABLET ISSUE ? Its bugging me badly that it messes my ping up :S
https://linustechtips.com/topic/111587-wi-fi-help/#findComment-1491924
The tablet's probably got some bugged up adapter or something. I don't know.
https://linustechtips.com/topic/111587-wi-fi-help/#findComment-1491938
Find a way to wire it through the floor. Drill a hole in a corner if you have to. In my house the router is in the family room and my room is also on the first floor so my ethernet cable goes from the router, into the basement, across the basement ceiling, up the side of the stairs, and into my room. (About 2 feet away from basement door.) I was going to drill a hole but my dad didn't think it would be worth it.
NZXT Phantom|FX-8320 @4.4GHz|Gigabyte 970A-UD3P|240GB SSD|2x 500GB HDD|16GB RAM|2x AMD MSI R9 270|2x 1080p IPS|Win 10
Dell Precision M4500 - Dell Latitude E4310 - HTC One M8
$200 Volvo 245
https://linustechtips.com/topic/111587-wi-fi-help/#findComment-1491940
Yes i know about that too.... but i dont have a basement, and we can't drill a hole through the ceiling :/ i guess i'll have to buy a wi-fi network card :/ because i have enough connection on the wi fi there i just wanted a stable connection :/
https://linustechtips.com/topic/111587-wi-fi-help/#findComment-1491961
Well, you should get the powerline thing that people were talking about above.
$200 Volvo 245
https://linustechtips.com/topic/111587-wi-fi-help/#findComment-1491996
