Hi guys!
I'm making a website with but i can't get the menu as i want it.. It is suppost to be on the left side and in the middle of every screen size (not mobile) and scroll with you so it is there at all times but i don't know how to do that, Please help!
[CPU: AMD FX-6100 @3.3GHz ] [MoBo: Asrock 970 Extreme4] [GPU: Gigabyte 770 OC ] [RAM: 8GB] [sSD: 64gb for OS] [PSU: 550Watt Be Quiet!] [HDD: 1TB] [CPU cooler: Be Quiet! Shadow Rock Pro Sr1]  -Did i solve your question/problem? Please click 'Marked Solved'-
https://linustechtips.com/topic/111571-help-with-website-menu/
position: fixed
That makes it stay at the top but shorter and not at the left side
https://linustechtips.com/topic/111571-help-with-website-menu/#findComment-1491538
