I believe the LL series require a Lighting Node Pro or Corsair Commander to address RGB. I'm fairly certain their connector is proprietary in that regard.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/1115165-chassis-fans/#findComment-12979115
Corsair fans need the icue software and only work on the lighting node pro or commander pro
Folding Stats
SYSTEM SPEC
AMD Ryzen 5 5600X | Motherboard Asus Strix B550i | RAM 32gb 3200 Crucial Ballistix | GPU Nvidia RTX 3070 Founder Edition | Cooling Barrow CPU/PUMP Block, EKWB Vector GPU Block, Corsair 280mm Radiator | Case NZXT H1 | Storage Sabrent Rocket 2tb, Samsung SM951 1tb
PSU NZXT S650 SFX Gold | Display Acer Predator XB271HU | Keyboard Corsair K70 Lux | Mouse Corsair M65 Pro
Sound Logitech Z560 THX | Operating System Windows 10 Pro
https://linustechtips.com/topic/1115165-chassis-fans/#findComment-12979138
2 minutes ago, YooBro said:
So if I have The lighting node pro or commander pro it should work fine with my mobo right?
Some mobo have a Corsair RGB connector
CPU:i7 9700k 5047.5Mhz All Cores Mobo: MSI MPG Z390 Gaming Edge AC, RAM:Corsair Vengeance LPX 16GB 3200MHz DDR4 OC 3467Mhz GPU:MSI RTX 2070 ARMOR 8GB OC Storage:Samsung SSD 970 EVO NVMe M.2 250GB, 2x SSD ADATA PRO SP900 256GB, HDD WD CB 2TB, HDD GREEN 2TB PSU: Seasonic focus plus 750w Gold Display(s): 1st: LG 27UK650-W, 4K, IPS, HDR10, 10bit(8bit + A-FRC). 2nd: Samsung 24" LED Monitor (SE390), Cooling:Fazn CPU Cooler Aero 120T Push/pull Corsair ML PRO Fans Keyboard: Corsair K95 Platinum RGB mx Rapidfire Mouse:Razer Naga Chroma  Headset: Razer Kraken 7.1 Chroma Sound: Logitech X-540 5.1 Surround Sound Speaker Case: Modded Case Inverted, 5 intake 120mm, one exhaust 120mm.
https://linustechtips.com/topic/1115165-chassis-fans/#findComment-12979144
Yes, it connects via USB header on the motherboard
12 minutes ago, YooBro said:
Any suggestion how many fans should I get? 120mm 3fans or 140mm 2fans?
depends on your case and what it can take.
Folding Stats
SYSTEM SPEC
https://linustechtips.com/topic/1115165-chassis-fans/#findComment-12979177
Thermaltake H200, either 120mm or 140mm is compatible but price wise 140mm is cheaper but I'm not sure is there any pros & cons between 120mm/140mm.
https://linustechtips.com/topic/1115165-chassis-fans/#findComment-12979180
If its for case fans the 140mm have higher flow rate @ 51.5CFM vs 43.25 CFM on the 120mm
they are both similar in noise
and the bigger ones look better in RGB
i have the 140 in my case
Folding Stats
SYSTEM SPEC
https://linustechtips.com/topic/1115165-chassis-fans/#findComment-12979190
Thanks, I go for 140mm then
https://linustechtips.com/topic/1115165-chassis-fans/#findComment-12979248
