Hi Guys,
I need help as i am trying to fix this for 3 days now. i bought a RX 580 nitro + 8gb, and its giving me crashes when i start two minute of kombuster or crashes a game. by crash i means black screen and then the audio goes off and the power is still on. i will have to restart in order to get it working again. but after the first crash i am able to run kombuster for 1 hour 40 minute with no issues at all, i started gaming on apex for a while and no issue for the entire duration.
I have DDU Nvidea driver and AMD and use auto detect from AMD to install the new driver "Adrenalin 2019 Edition 19.9.2 Recommended (WHQL)".
When i do run the graphic card in kombuster temp never exceed 74, i am also able to run 980 ti without a problem (tested a friends graphic card for 2 hours).
i have:
CPU: i5 2400
Graphic card: RX 580 Nitro
Ram: 16GB
Psu: 600W EVGA
Motherboard: ASUS® P8H61-M LE/USB3
Monitor: Acer 24 inch (using HDMI)
The card is not faulty as i have tested it on another machine which works fine. so why do i keep getting black screen randomly?
i would really appreciate someone helping me here.
p.s i use to have a 660 ti and it never gave me issue when running anything this is the first time i use AMD product.
Below is the setting or info in regards to my card
https://linustechtips.com/topic/1115021-urgent-help-please/
Is anything on your system overclocked?
Have you checked the event viewer in Windows, to see if any error is given?
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
https://linustechtips.com/topic/1115021-urgent-help-please/#findComment-12978027
3 minutes ago, Stevenkun said:
Hi,
Can you please tell me what stability issues has it patched? and do you think it will resolve the issue and if so why does it not occur with Nvidea cards?
i think that is irrelevant i would just update the bios and test it out see if it made a difference in stability
https://linustechtips.com/topic/1115021-urgent-help-please/#findComment-12978078
Hi,
Do i just download the latest one and update the bios or do i need all the previous ones as well? sorry i dont mean to offend anyone i am just clueless and trying to understand whats happening to my pc.
https://linustechtips.com/topic/1115021-urgent-help-please/#findComment-12978104
just the latest one and follow the instruction on the site for how to install it.
theres a chance it wont fix the problem but with such an old board its worth a shot at least
https://linustechtips.com/topic/1115021-urgent-help-please/#findComment-12978125
I have updated the bios to the latest one and ddu uninstall and reinstall the latest driver. The kombuster seem to went past the two minute frozen mark. But I don't know if it will stay stable. What else would I need to do if this fails?
https://linustechtips.com/topic/1115021-urgent-help-please/#findComment-12978208
nothing , just wait and keep testing and if its more stable then problem solved. come back if the issues persist
https://linustechtips.com/topic/1115021-urgent-help-please/#findComment-12978338
Thank you for kindness and willingness to help. not sure if this works 100% but at least its worth a try until the next few days.
again thank everyone who helped!!! amazing community
https://linustechtips.com/topic/1115021-urgent-help-please/#findComment-12978346
