Hello guys Im here again I returned my Cpu and my mainbaord ( ryzen 2700x and asrock b450m steel legend) and bought new ram corsair 16gb 3000mhz and again build all the things into my case .
After that I tried to boot and again thr CPU cooler doesnt starts and my screen is black.
So I removed again the battery and like last the time the cpu cooler started working but the screen is still black
https://linustechtips.com/topic/1114986-help-pls/
Do you have a graphics card? The 2700 doesn't have integrated graphics.
What parts are you using?
https://linustechtips.com/topic/1114986-help-pls/#findComment-12977717
Try to boot with only one RAM stick. If that doesn't work, change the channel that the RAM stick is in and try again. Repeat if you have multiple RAM sticks. If it never works with a new stick, but works with different RAM, the new stick of RAM is faulty. Make sure the basic things are also secure, like the display cable and all power cables.
Hello there, fellow dark theme users
"Be excellent to each other and party on dudes." - Abraham Lincoln    #wiiumasterrace
https://linustechtips.com/topic/1114986-help-pls/#findComment-12977719
