So my old gaming laptop is broke and I don't realy game that hard anymore but still play war thunder here and there and i'm on a $100 or less and I got hooked to a HP probook 645 g1 with a AMD A10-5750m 2.5gz and 4gb ddr3 ram I have more sodimms from an old project.  Could this get by on the old gpu mode on war thunder at around 30-40 fps or should I look for something more high end?
https://www.ebay.com/itm/HP-Probook-645-G1-AMD-a10-5750m-2-5GHz-4-GB-RAM-250-GB-HDD/223691814341?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3D68721d7303064babbfccea9422c6178e%26pid%3D100675%26rk%3D2%26rkt%3D15%26sd%3D174037998390%26itm%3D223691814341%26pmt%3D1%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3Aa28faa40-f107-11e9-8878-74dbd1803771|parentrq%3Adade635316d0a4e92239396bfff547ae|iid%3A1
https://linustechtips.com/topic/1114940-help/
11 minutes ago, Faisal A said:
It has an AMD A10 CPU which will be like a R3 1700X
Even if you meant the 1300X, you can't get more wrong.
Desktop benching:
https://linustechtips.com/topic/1114940-help/#findComment-12977337
