my friend sent me this image. how do he proceed? he said, he move the harddisk from one laptop to another, and now ittl not showp up at the file explorer. and will it format the disk?
MORE INFO :
The Hardisk is external, the first time its used, it works normally. but after a lonng time not being used. when he tried to use it. it go like this(the picture).
https://linustechtips.com/topic/1114631-unallocated-disk-help/
1 minute ago, Kuroneko827 said:
how do he proceed?
From Windows perspective, it's already "formatted". The file system on the drive must be something Windows doesn't understand (Linux or Mac?), or the drive was in some sort of RAID previously.
If there are things your friend wants to keep, put the drive back where it came from and copy stuff off before proceeding. If not, go ahead and click "OK" and format the drive for the file system of choice.
Main System (Byarlant): Ryzen 9 5950X | Asus B550-Creator ProArt | EK 240mm Basic AIO | 32GB G.Skill DDR4 3600MT/s CL16 | XFX Speedster SWFT 210 RX 6600 | Samsung 990 PRO 2TB / Samsung 990 EVO Plus 4TB | Corsair RM750X | StarTech 4× USB 3.0 Card | Realtek RTL8127 10G NIC | Hyte Y60 Case | Dell U3415W Monitor | Keychron K12 Blue (RGB backlight)
Laptop (Narrative): Lenovo Flex 5 81X20005US | Ryzen 5 4500U | 16GB DDR4 3200MT/s (soldered) | Vega II 384SP Graphics | SKHynix P31 1TB NVMe SSD | Intel AX200 Wifi | Asus 2.5G USB NIC | Asus ProArt PA278QV | Keychron K4 Brown (white backlight)
Proxmox Server (Veda): Ryzen 7 3800XT | ASRock Rack X470D4U | Corsair H80i v2 | 128GB Micron DDR4 ECC 3200MT/s | 2× Samsung PM963a 960GB SSD / 4× WD 10TB / 4× Seagate 14TB Exos / 4× Micron MX500 2TB / 8× WD 12TB (custom external SAS enclosure) | Seasonic Prime Fanless 500W | Intel X550-T2 10G NIC | LSI 9300-8i HBA | Adaptec 82885T SAS Expander | Fractal Design Node 804 Case
Proxmox Server (La Vie en Rose)GMKtec Mini PC | Ryzen 7 5700U | 32GB Lexar DDR4 (SODIMM) | Vega II 512SP Graphics | Lexar 1TB 610 Pro SSD | 2× Realtek 8125 2.5G NICs
Media Center/Video Capture (Jesta Cannon): Ryzen 5 1600X | ASRock B450M Pro4 R2.0 | Noctua NH-L12S | 16GB Crucial DDR4 3200MT/s | EVGA GTX750Ti SC | UMIS NVMe SSD 256GB / TEAMGROUP MS30 1TB | Corsair CX450M | Viewcast Osprey 260e Video Capture | TrendNet (AQC107) 10G NIC | LG WH14NS40 BD-ROM | Silverstone Sugo SG-11 Case | Sony XR65A80K
Workbench (Doven Wolf): Lenovo m715q | Ryzen Pro 3 2200GE | 16GB Crucial DDR4 3200MT/s (SODIMM) | Vega 8 Graphics | SKHynix (OEM) 256GB NVMe SSD | uni 2.5G USB NIC | HDMI add-in module
Network:
                       ┌─────────────── Office/Rack ───────────────────────────────────────────────┐
Google Fiber Webpass ── Cloud Gateway Max ══╦═ Pro XG 8 ══╦═ Flex 2.5-8 ══╦═ Doven Wolf
                      La Vie en Rose (DNS) ═╬═ Narrative  ╠═ Veda-NAS     ╠═ La Vie en Rose (vmbr)
                                Veda (DNS) ─┘             ╠═ Veda (vmbr)  ├─ Ptolemy (vmbr)
╔═════════════════════════════════════════════════════════╩═ Ptolemy-NAS  ├─ Veda (Mgmt)
║   ┌ Closet ┐      ┌───────── Bedroom ─────────┐                         └─ Veda (IPMI)
╚═══ Flex XG ══╦╤═══ Flex XG ══╤╦═ Byarlant
       (PoE)   ║│              │╠═ Narrative
Kitchen Jack ══╣└─ Dual PoE ┐  │╚═ Jesta Cannon*
   (Testing)   ║┌─ Injector ┘  └── Work Laptop
     Bedroom ══╝│        ┌─────── Media Center ────────────────────────────┐
     Jack #2    └──────── Switch 8 ────────────┬─ nanoHD Access Point (PoE)
Notes:                                         ├─ Sony PlayStation 4
─── is Gigabit / ═══ is Multi-Gigabit          ├─ Pioneer VSX-S520
* = cable passed from Bedroom to Media Center  └─ Sony XR65A80K (Google TV)
https://linustechtips.com/topic/1114631-unallocated-disk-help/#findComment-12974564
so if he click ok, the disk will be formatted?
https://linustechtips.com/topic/1114631-unallocated-disk-help/#findComment-12974578
Short answer: yes, in that all the files will be gone.
Longer answer: not yet, but it will probably destroy whatever other formatting is on the disk. That prompt is asking which type of partition map to create, which will overwrite whatever one was there before (if there was one? Usually that only applies to drives that are brand new...). You can then create a partition and format it with a file system, at which point it will show up as a drive in Windows.
Network:
https://linustechtips.com/topic/1114631-unallocated-disk-help/#findComment-12974590
Doesn't look formatted to me... Might be that the partition table is missing.
Just click OK and it will create the partition table.
Please mention or quote me if you want a response. :)
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
¯\_(ツ)_/¯
https://linustechtips.com/topic/1114631-unallocated-disk-help/#findComment-12974594
Yup, no partition table.
You did not say anything about what you want. Do you jsut want to use the disk or are there files on it that need recovering? The instructions are NOT the same at all in a case or the other.
F@H
GPD Win 2
https://linustechtips.com/topic/1114631-unallocated-disk-help/#findComment-12974598
Hence my air-quotes. From the common perspective of "formatted = no files", it's true, but no, technically it's not formatted, you're right.
Network:
https://linustechtips.com/topic/1114631-unallocated-disk-help/#findComment-12974600
thank you so much for your answer. i added some more info, will  it be of help? to determine what to do?
he does want the file in the disk. and doesnt want it fromatted
https://linustechtips.com/topic/1114631-unallocated-disk-help/#findComment-12974636
Then do not touch or "OK" anything. Give it to someone who has experience in data recovery and is able to try and recover the partition table.
F@H
GPD Win 2
https://linustechtips.com/topic/1114631-unallocated-disk-help/#findComment-12974640
