so i need exact instructions. Ive tried watching videos and learning i dont get it.
ive got corsair 3600mhz ram 2x8gb.
asus b450 f mobo
im running the memory profiles so 1.35v i think it is cl18 i think it is, i get black screen restarts sometimes. think the max my mobo supports is 3200.
How exactly, instructions i can follow step by step, do i downclock my ram to 3200 or 3400 even??
how much performance will i lose??
edit running ryzen 3600
EDIT: So seems my mobo supports it so we're onto some further troubleshooting why am i getting black screen restarts below read latest post or such.
https://linustechtips.com/topic/1114367-need-help-with-ram/
asus b450 f mobo
what cpu are you running?
Internet Connection
My Rig: AMD Ryzen 9 3900X @ 4.3Ghz | Asus Prime X470-Pro | Corsair Vengeance RGB Pro 32 GB (4 x 8GB) DDR-4 3000Mhz OC'd @ 3400Mhz 16-20-20-38 |
EVGA RTX 2070 8GB XC Gaming OC @ 2145Mhz Boosted/ 1925Mhz Memory | WD SN750 500GB M.2 NVME | Gigabye 240GB SSD |
XSPC EX 360mm | Corsair XC7 RGB CPU WB | EK-Vector RTX 2080 | Alphacool Eisbecher D5 150mm Plexi | XSPC Fittings | XSPC FLX Clear 7/16" ID, 5/8" OD |
Corsair LL120 x6 | Corsair RM750x White 2018 | Corsair Commander Pro | Corsair Obsidian 500D RGB SE | Corsair RGB LED Lighting PRO Expansion |
Corsair Strafe RGB MK.2 | Corsair Ironclaw RGB Wireless 18,000DPI | Acer 32" 4K 60Hz HDR600 Cert. ET322QK CBMIIPZX |
Passmark Score
3dmark Score
PC Parts Picker Link to Build
Network
Netgear LBR20 LTE Router | Verizon Unlimited Prepaid Hotspot Plan
HP 2530-48G-PoEP Switch
Rasberry Pi 4 Running Pihole
Linksys Velop 3 Mesh Wifi AP's
https://linustechtips.com/topic/1114367-need-help-with-ram/#findComment-12972243
Just now, The Torrent said:
3600
That board supports up to 4400Mhz memory with 3rd gen ryzen cpus.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1114367-need-help-with-ram/#findComment-12972249
1 minute ago, The Torrent said:
3600
Make sure your bios is up to date DOCP is enabled in bios and check the timings to make sure they applied correctly in bios.
Open event viewer and try to find the log from the restart to see if you can narrow it down.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1114367-need-help-with-ram/#findComment-12972258
Product pages never get updated, go to support, and CPU/Memory Support and download Memory QVL for 3rd Gen ryzen, max speeds are 4400Mhz,
2nd gen max is 3200Mhz.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1114367-need-help-with-ram/#findComment-12972267
image.thumb.png.6edd67d3df478269c2c5e688144201e2.pngis this the correct one??? Is it possible to install without a usb?
https://linustechtips.com/topic/1114367-need-help-with-ram/#findComment-12972306
wait i just realised it says downloaded......
but i doubt its installed then if im getting black screen... what do i do?
https://linustechtips.com/topic/1114367-need-help-with-ram/#findComment-12972311
Yes, all that is a PDF list of memory kits officially supported by your board. Nothing to install. With Ryzen 3rd gen CPU most non X570 boards can support higher memory than the original spec.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1114367-need-help-with-ram/#findComment-12972314
but i get black screen restarts then... o oh... why is that?
https://linustechtips.com/topic/1114367-need-help-with-ram/#findComment-12972316
Your memory most likely isn't the issue but to rule it out you can run memtest to check for memory errors, i like to let it run overnight. https://www.techpowerup.com/memtest64/
I think your issue lies else where.
Internet Connection
Passmark Score
3dmark Score
Network
https://linustechtips.com/topic/1114367-need-help-with-ram/#findComment-12972327
