Hello everybody,
I’m building a new gaming pc and I’m trying to find the right PSU. I’ve seen many guides and forums but when I look at the reviews of any PSU there’s always people talking about them failing.
I just want to know which 650 Watt reliable PSUs are there on the market that are under 100$. Which ones should I trust?
I’ve also looked at the tier list posted on this forum. And I wanted to know if the B tier (Budget) PSUs can be trusted.
My parts are:
CPU: AMD Ryzen 5 26000
Motherboard: Gigabyte B-450 AORUS ELITE
RAM: G.Skill RipJaws 5 Series (2x4GB) 3200mhz
GPU: Sapphire NITRO+ RX 590
Thank you very much for your help and comments.
Mauricio.
https://linustechtips.com/topic/1114022-help-me-find-a-psu/
Why 650? Is noise an important factor?
definitely.
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/1114022-help-me-find-a-psu/#findComment-12969212
Just now, maurilm said:
I just want to be able to upgrade in the future.
a 550 watt PSU can power any high end system out there, you can save a little money with something like that
https://pcpartpicker.com/product/CZvZxr/bitfenix-whisper-m-550w-80-gold-certified-fully-modular-atx-power-supply-bp-wg550umag-7fm
Primary PC:
PSU tier list
https://linustechtips.com/topic/1114022-help-me-find-a-psu/#findComment-12969226
Awesome man, thanks for your input
https://linustechtips.com/topic/1114022-help-me-find-a-psu/#findComment-12969283
