My old laptop has a problem, when on battery power the backlight is so dim that it's barely visible at night in a dark room.
When plugged in it has some white horizontal stripes on top (~1cm in total)
The stripes occurred after I changed the thermal paste, but they usually disappear after pressing the lower right corner of the screen. The backlight problem occurred later
https://linustechtips.com/topic/1113935-display-problems-on-laptop/
Sounds to me like you might have messed up your display’s ribbon cable on re-assembly. You can often find replacement screens or cables on eBay cheapish.
