Hello all,
I am running the following setup:
- A Ryzen 5 3600 with an EK-Velocity Nickel waterblock;
- A GTX 1080Ti with an EK Nickel waterblock;
- A 240 Performance Edition radiator;
All components are running at stock speeds. On Aida64, my GPU reaches up to 55C under stress, where as my CPU, a much less power-hungry component, reaches over 70C. Watercooled, at stock speeds.
I have tried reapplying thermal paste multiple times, using different levels of "tightness" on the waterblock screws, completely reassembling the loop, etc. My CPU is running hotter than normal, and I am running out of options.
The same issue happened when I had a different motherboard, and a Ryzen 1600. Any ideas?
My rig:
Quote me so I can reply back :)
MY PC-> PSU: EVGA SuperNOVA T2 1000W 80 Plus Titanium MOTHERBOARD: ASUS X370 Crosshair VI Hero CPU: RYZEN 7 3700X RAM: G.Skill 32GB (4X8GB) DDR4 3200MHz C14 GPU: EVGA GTX 1080Ti FTW3 HYBRID STORAGE: Samsung 970 EVO 500GB NVMe SSD; 2TB WD Caviar Blue; Crucial MX500 500GB SSD CUSTOM LOOP: EK-Velocity Nickel + Plexi CPU block, EK-FC1080 GTX Ti Acetal + Nickel GPU Block w/ EK-FC1080 GTX Ti Backplate, EK-XRES 140 Revo D5 PWM, EK-CoolStream PE 240 w/ 2x Noctua NF-F12 Chromax fans, EK-ACF Fitting 10/13mm Nickel, Mayhems UV White tubing 13/10mm, 3x Noctua NF-S12A Chromax case fans
https://linustechtips.com/topic/1113795-watercooling-temperature-issue/
You're using a single 240mm rad for both the CPU and GPU?
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
8 minutes ago, Firewrath9 said:
A single EK rad for a high heat GPU and a CPU?
Is it a EK slim rad? those are trash.
what fans?
Noctua NF-F12 fans. Also, the radiator is a Performance Edition one. It's thicker.
Yes, I am, it should be enough, to be honest.
Depends, are you running 4 fans in push/pull or just two fans?
What are your fan speeds? If you have a thicker radiator in order to keep cooler temps the fans have to be at a higher speed.
Sounds like you don't have enough airflow or you need a bigger rad.
45mm or 60mm? EK has decent 60mm rads but the 45mm is pretty bad.
F12s are meh compared to other fans such as SW3s, ML120s, Gentle Typhoons, Vardars.
Thanks for the input, however the airflow is more than sufficient, I am not running a side panel, or front panel. Also, the radiator is sufficient for both components, and the issue persists even when I only stress test the CPU.
not necessarily. It depends on FPI. The old HWLabs GTS w/ a 30 FPI actually outperformend the large, 60mm thick SR2 with a 9 FPI core, even more so with higher fan speed.
