Moar Speed!!!!
Go to solution Solved by Skiiwee29,
You would need a layer 3 device, either a router, or layer 3 switch where you can do ether bonding and load balance between the 2 connections to get the 800x40 connection with the 2 400x20 installs. Only way to do it in windows would be if you have Server edition.
I'm experiencing for the fist time hardwired Ethernet internet connection. When i was in my Apt. i had to get a wireless card to use the wifi because my router had to be in the living room (i had no coax in my room and they couldn't drill. i'm a Spectrum Tech now so i understand)  I'm no my new place and i got to put my modem and route next to my PC and gaming stuff.  I was wondering if i get a networking card if i'd be able to use 2 400x20 hard wired connections (one on the networking card and one on the motherboard) if i'd essentially be able to have 2 400x20 connections making it faster. i don't think  it works like that but you never know. because math says 2+2=4
https://linustechtips.com/topic/1112903-moar-speed/
You won't get faster internet by adding more connections to your router if that's what you're asking.
¯\_(ツ)_/¯
Desktop:
Intel Core i7-11700K | Noctua NH-D15S chromax.black | ASUS ROG Strix Z590-E Gaming WiFi  | 32 GB G.SKILL TridentZ 3200 MHz | ASUS TUF Gaming RTX 3080 | 1TB Samsung 980 Pro M.2 PCIe 4.0 SSD | 2TB WD Blue M.2 SATA SSD | Seasonic Focus GX-850 Fractal Design Meshify C Windows 10 Pro
Laptop:
HP Omen 15 | AMD Ryzen 7 5800H | 16 GB 3200 MHz | Nvidia RTX 3060 | 1 TB WD Black PCIe 3.0 SSD | 512 GB Micron PCIe 3.0 SSD | Windows 11
https://linustechtips.com/topic/1112903-moar-speed/#findComment-12960788
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1112903-moar-speed/#findComment-12960806
