Hi everybody i could really use an informed input on a decision tight now. I am building a pretty stout new computer and i want to upgrade the monitor. I im really liking the dell 49” ultrawide at this point (financing is a factor) mostly because its basically 27x2 bezel-les so for work flow it would be amazing. it is 1440 but only 60hrz, so im wondering if they will upgrade to higher hertz within the next 6months, cause then id wait for that. What do you guys think?
https://linustechtips.com/topic/1111762-help-with-49%E2%80%9D-ultrawide/
It's not very likely for a product in that form factor, unless the monitor is targeted towards gamers
Current system - ThinkPad Yoga 460
ExSystems
Laptop - ASUS FX503VD
|| Case: NZXT H440 ❤️|| MB: Gigabyte GA-Z170XP-SLI || CPU: Skylake Chip || Graphics card : GTX 970 Strix || RAM: Crucial Ballistix 16GB || Storage:1TB WD+500GB WD + 120Gb HyperX savage|| Monitor: Dell U2412M+LG 24MP55HQ+Philips TV ||  PSU CX600M ||
If you want this size in 120Hz, go for the Samsung CRG9... but it suffers from flickering with Nvidia GPUs and isn't cheap. If Dell DO release a similar version though, it will be even more expensive.
System: Ryzen 7 5800X - Gigabyte X570 Aorus Master - Noctua D15S Chromax - 32GB 3600 RAM - EVGA Black 2080Ti
