4 minutes ago, Pancakewagon26 said:
Z390 and Z370
USB support is different, otherwise nothing limited by the chipset
i7 8700k
Gigabyte Aorus boards are definitely much stronger in power delivery than even the Z390-F, while Asrock Phantom 6 gives better troubleshooting features (post code display). Dont see the point of going Asus on Z370 nor Z390 (except the Apex and Gene)
Desktop benching:
Gigabyte has a nice lineup. Generally good power delivery and VRM cooling, along with some solid aesthetics. Z370 would be easier on the wallet without sacrificing much.
"uhhhhhhhhhh yeah id go with the 2600 its a good value for the money"
Thanks! I will look into it.
7 hours ago, Pancakewagon26 said:
Recently fried my motherboard and am searching for a replacement, should I just buy a new one or are options like the ROG Z390F worth it, and is there any substantial difference between Z390 and Z370? Currently I have a 1070 and a i7 8700k
I upgraded my Z370-H to a Z390-F when I OCed my 8600k.
Before I changed my mobo I had trouble going over 4.8ghz due to unstable power delivery from the Z370-H.
I could achieve a higher overclock with less voltage on the Z390-F.
The Z390-F is definitely a good mobo and a solid match for the 8700k (especially if you want to OC) but there are plenty of other good mobo as well.
CPU: i9 9900K   Cooler: NH-D15   RAM: Kingston Fury 4 x 8GB 3600MHz CL17   Mobo: ASUS ROG Strix Z390-F   GPU: ASUS 3080 TUF   Case: In Win D-Frame   PSU: Corsair HX850i   Storage: 250GB Samsung 970 EVO NVMe (OS), 500GB Samsung 970 EVO NVMe (Games), 2TB Crucial BX500 SSD (Storage)   Monitor: Samsung Odyssey Neo G9.
